Stopping front end sag while plowing
Old Jan 18, 2011 | 01:31 AM
noooooo's Avatar
Default Stopping front end sag while plowing
I have a 2009 850 with a 60" moose plow with a mibar down pressure and a moose hydro turn kit. The front sags quite a bit even with the springs adjusted. I was thinking of taking a piece of steel shaped like the letter "I" that replaced the front shock. It would be the same length and bolt size as the shock. It would lock out the front suspension. I only use the quad during the winter to push snow. If I did this what suspension/drivetrain components would it be rough on?
Old Jan 18, 2011 | 07:01 AM
lovmudd's Avatar
I'm thinking you would be OK as long as you still use rubber bushings at the fastening points to prevent metal to metal contact and absorb road shock.
Having said that, I would instead recommend heavier frt springs, which is what most do to prevent the sag.
Old Jan 18, 2011 | 09:33 AM
TLC's Avatar
TLC
Does the XPs come with HD (Heavy Duty) springs stock? If so you can also add spring spacers.
Gtsordo
Jul 13, 2015 10:38 PM
toonces
Jul 11, 2015 12:01 PM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
cornermike
Jul 8, 2015 11:44 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
