07 griz 660 buzzes when start button pushed
Old Jan 19, 2011 | 04:45 PM
Graybeard14's Avatar
Question 07 griz 660 buzzes when start button pushed
I have an 07 660 griz that the start relay buzzes when you press the starter button. We replaced the battery a couple months ago and elect start worked fine. After the relay started to buzz, we replaced it. Still buzzes when we press the starter button and no action in the starter area.
You can pull start it, not easily, but it starts and runs well. Any thoughts before we disassemble to get at the starter?
Thanks
Old Jan 19, 2011 | 05:24 PM
snow racer's Avatar
Try to jump start it
Old Jan 22, 2011 | 03:15 PM
kcaves's Avatar
Make sure all ur connections are tight, and u hooked up all ur wires correctly
Old Jan 22, 2011 | 04:56 PM
draarong2004's Avatar
sounds to me like a low battery, how cold is it there? do you have a trickle charger? i recomend one, even a cheap one will get the job done and save you batteries
Old Jan 23, 2011 | 08:33 AM
right now the computer is saying -17 F. We have had the charger on, but waiting for it to warmup a little before we check the wires under the body work. thank you for the ideas, we will let you know (am just hoping it is not a $300 starter)
Old Jan 23, 2011 | 11:10 AM
yea i'm gonna go with a really low battery, i've got a trickle charger on my quad(no idea the age of the battery, prolly old enough to be replaced) and when it gets under 10 it won't start unless i jump it
Old Jan 30, 2011 | 04:55 PM
We found a bunch of very corroded wires and connects (griz was once a submarine in a previous life). Disassebled everything, soaked in Coke-Cola and wire brushed. now everything works great. Thanks for the help!
Old Feb 9, 2011 | 07:40 AM
garyc660R's Avatar
What kind of battery did you go with a few months ago?
Old Feb 9, 2011 | 09:11 AM
a Road Runner Premium AGM Power Sport Battery from a local Mill's fleet Farm store.
2x_lung
1) Engine problems..
48
May 24, 2023 05:22 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
BEEFKING69
Jun 17, 2015 12:38 AM
jayking232003
Jun 9, 2015 02:54 PM
1000gade
May 27, 2015 12:37 PM
