warrior problems
Old Jan 24, 2011 | 05:31 PM
JOKERUNLIMITED's Avatar
Default warrior problems
I have a 03 Yamaha Warrior 350 and i am having problems with it now to where it will run great for about 10 minutes then it will shut off and not restart fro about 30 minutes. Can anyone give my some pointers on getting it back on the trail? I have put a new plug in, added a fuel filter, cleaned the air filter, had the valves checked, rebuilt the carb. I dont know what else i can do. Please help
Old Jan 24, 2011 | 06:48 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
Bad coil maybe?
Old Jan 25, 2011 | 10:18 AM
Where is the best place to get one? I dont want to buy an expensive one and find out that is not the problem. Thanks raptorlegs
Old Jan 27, 2011 | 02:40 PM
Raptorlegs's Avatar
T Rex Rider
Unfortunately, when you wrench in the garage, its real easy to fix things that aren't broken. Nature of the beast. But try your local dealership. If not, I've had good experience with Rocky Mountain atv online.
Old Jan 28, 2011 | 01:23 PM
Cool thanks. What do you think about bike bandit, or ebay? I found a performance cdi and rev limiter for 80.00 plus shipping would that be a good chance to take? I had a shadetree bike mechanic tell me it is the on off switch on the handlebar that the spring is losing tension. Does that sound like a possibility?
Thanks again
Old Feb 24, 2011 | 12:12 PM
CNorth's Avatar
Since it seems like you're not sure where the problem lies I'd do some more testing before spending any money. I'd doubt it's the killswitch because if it were you should just be able to flick it off and on and then easily be able to restart your engine.
Check to make sure you're getting spark after it shuts off when cranking. If you don't then it's probably your coil.
Reactant
Mar 30, 2022 02:08 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
Reactant
Jul 16, 2015 10:29 PM
