Winch wire size
Old Jan 28, 2011 | 02:14 PM
bcdudley's Avatar
Default Winch wire size
Just wondering what everyone else is running for wire size to their winch. I currently have 00, but it is old and crunchy. I was going to swap it out. Is 10 gauge big enough, or should I go beefier?
Thanks,
Old Jan 28, 2011 | 05:17 PM
bcdudley's Avatar
hmm, just found the Warn Winch spec sheet for it. It says 6 gauge wire. It also says it can pull up to 204 amps. I currently have a 100amp fuse on it. I guess I need to bump that up to a 225 amp.
Old Jan 28, 2011 | 05:23 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
10ga will hold a good amount of current- but those winches can draw a mighty load when torquing out. I'd go thicker...
Old Jan 28, 2011 | 05:55 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
thats like the only differnce form the old 2000 vs the 2,500 warns was a heavier gauge wire which as mentioned will hold more power.
Old Jan 29, 2011 | 01:33 AM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
You'll want to be careful running a smaller gauge wire. The higher the amperage gets the hotter the wires will get. Possible melt down or fire if you run to small and they get hot enough. 10ga. would be the absolute smallest I'd run on my personal equipment.
Old Jan 29, 2011 | 01:44 AM
bcdudley's Avatar
I went with 6 gauge. I crimped and soldered on the ring terminals. It worked good for a few minutes, but then I started having other problems. Starting a different thread for different problems. Thank for the advice.
toonces
Oct 19, 2015 02:21 AM
Schneider
Jul 24, 2015 05:05 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
