Smoke in Oil Check Window
Old Feb 8, 2011 | 07:23 PM
TimberXX's Avatar
Default Smoke in Oil Check Window
My kawasaki bayou 220 has a oil check window as a way to ensure the correct amount of oil is in the engine. The last time I rode, I noticed I was a little low in oil, and the window that wasn't covered in oil was covered in white smoke.
Any idea what this is?
Old Feb 8, 2011 | 08:05 PM
King Quad's Avatar
are you sure it was smoke. If it is milky looking liquid it could be coolant in the oil.
Just a thought if that is the issue you have a bad head gasket.
If that is the case start it up and watch the pipe there will be white smoke when you fire it up till it warms up.
If it is air cooled that I am way off base
Old Feb 9, 2011 | 07:01 PM
TimberXX's Avatar
it is air cooled, i think it may be little water vapor.
but opinions are welcome
Old Feb 9, 2011 | 07:56 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
compression check- maybe a burnt ring or a scored cylinder allowing blow-by into the crank (where your sight window is)
also- don't know much about those motors- but if there's a clogged breather vent for the crankcase- it could be preventing gasses from properly venting...
Old Feb 9, 2011 | 07:58 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
+1
could be that too-
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
dirt ryder
Sep 27, 2015 09:22 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
