07,500 sportsman,Front Differential Bearing
Good day,
I have the seal and bearing on my front diff input shaft gone bad.
The seal is leaking and the bearing is shot.
I have removed the cover that holds the seal and small bearing by removing the 3 bolts.
I want to replace the larger bearing next. Can that come out with the diffferential in the bike? If i take out the circlip will it come out easily?
has anyone done this before?
you might be able to do a search for it onthe site as i seem to remember(not 100%) reading in here that some one had done the front end seal and maybe bearing? you could always try to remove the C clip and see and if not then remove the whole assembly.
