07,500 sportsman,Front Differential Bearing
Old Feb 11, 2011 | 08:39 AM
katt68's Avatar
Default 07,500 sportsman,Front Differential Bearing
Good day,
I have the seal and bearing on my front diff input shaft gone bad.
The seal is leaking and the bearing is shot.
I have removed the cover that holds the seal and small bearing by removing the 3 bolts.
I want to replace the larger bearing next. Can that come out with the diffferential in the bike? If i take out the circlip will it come out easily?
has anyone done this before?
Old Feb 11, 2011 | 08:43 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you might be able to do a search for it onthe site as i seem to remember(not 100%) reading in here that some one had done the front end seal and maybe bearing? you could always try to remove the C clip and see and if not then remove the whole assembly.
Old Feb 12, 2011 | 05:52 AM
Kerbbirds's Avatar
If youv got the driveline off thats the hardest part, unplug electrical wires and tak bolts out from underneath, assembly will come out of frame where you can work on it
Old Feb 12, 2011 | 07:33 AM
katt68's Avatar
do i really have to remove axels and cv joints and pull out the gearcase?
Old Feb 12, 2011 | 02:03 PM
ramman67's Avatar
Default gear box
Just take snap ring out and input shaft and bearing will come out. You dont need to pull the whole gear box out of the machine.
neilbedwell
Nov 10, 2018 11:02 AM
yellowpolaris
Jun 21, 2015 11:13 AM
Biggieshortie89
May 26, 2015 08:01 AM
CanadianViking
Feb 16, 2001 11:56 AM
