Sport Quads Discussions on sport quads.
how do i shift?
Old Mar 9, 2001 | 06:22 PM
RJR99SS's Avatar
ok, my son brought a 99 warrior over for me to look after while he's away. never really rode an atv before so i gave it a try but i couldnt figure out how to shift gears in the thing. i figured out how to throw it in reverse and forward mode, but thats about it. so what do i do guys? forgive my ignorance.
Old Mar 9, 2001 | 08:25 PM
bermbanger's Avatar
Pull in the left lever on the handlebars and take your foot and push down on the shifter on the left side in front of the footpeg.Let out the clutch slowly along with some gas. When you get going in first pull in the clutch again and give it 1 hard shift into second. The next 4 gears are the same as those two. Neutral is between 1st and second and only takes a tap down from second to get it there. Give it to much gas when starting off and it'll wheelie away.
Old Mar 11, 2001 | 12:04 AM
AdrenalinFreak's Avatar
Incase you havent figured it out, 1st gear is shift down from neutral, After that all gears are shift up from neutral. In other wards, When in neutral, click down 1 time to get into first, then click up to get into 2,3,4,5,6 Other than that it has the same basic principles as a manual trans car or truck. As mentioned, neutral is between 1 and 2.
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
