05 Prairie 360 Carb problem
Old Feb 16, 2011 | 09:39 AM
05KAWASAKIPRAIRIE's Avatar
Default 05 Prairie 360 Carb problem
I have a 2005 Prairie 360 and noticed that when I have the gas on it leaks out of the drain tube. I took the carb apart to see what the problem was and the pin that is attached to the float bowl had broken off. The pin is just attached to the bowl. I don't think it serves any other purpose other than to keep the float up. My question is would I be able to fix it? Is there some way to attach it back on? Any help would be greatly appreciated.
Thanks
Old Feb 16, 2011 | 03:52 PM
Dirtjunkie85's Avatar
I am not familer with this exact machine but is this a seprate part? if so you can get a replacement part i am sure at Rocky Mountain at there OEM parts I am sure you need it but with out seeing it i am not for sure if it can be replaced check out there oem parts diagram and let me know what number you are looking at then I can try to help more here is a link just click on the oem tab and put in your machine then click on the carb diagram.
ATV Parts, ATV Tires, Dirt Bike Parts & Motocross Gear | Rocky Mountain ATV/MC
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
