Need info on sportsman 800 twin efi
Old Feb 16, 2011 | 06:29 PM
HaydenS's Avatar
Default Need info on sportsman 800 twin efi
I just bought one today with no miles on it. Its a 2006 I believe since it says 08-26-2006 under the front. It could be a 2007 I guess???????? anyways the guy (seller who used to own a shop but lost it in a divorce) could not find the key and I had to have one made at the local locksmith shop. This key turns the lights on but will not start the Machine. Is there something i'm not doing right to start this up and hear it run. Are the keys chipped (electronic key)???? Any help would be appreciated.
Old Feb 16, 2011 | 06:34 PM
Mud Slinger's Avatar
Did you get a title with it?
Old Feb 16, 2011 | 06:38 PM
HaydenS's Avatar
Yes, It's not stolen
Old Feb 17, 2011 | 12:46 AM
switzomatic's Avatar
No chips in the keys and I'm assuming you're turning it all the way clockwise. Check the battery/connections first. If it's low then it will need charging/replacing. Check your fuses and connections. Worst case could be a bad ignition switch or starter issue.
Old Feb 17, 2011 | 04:09 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
it seems kind or weird that this guy sells you this bike which has no miles but has no key?? if the key you had made turns the switch then it would start. did you get the owners manual w/ the bike? if so read in th book how to put the bike into the dianostic mode to check the voltage in the battery. just a thought, but that bike won't start in gear w/out pulling the hand brake or it needs to be in park or neutral.
Old Feb 17, 2011 | 08:07 AM
HaydenS's Avatar
I purchased a brand new Battery and I have a new ignition switch on the way. The locksmith used a blank key (no cuts in blank) and it turned the switch. Like I said this key will turn the dash on but I'm wondering if it is not turning all the way to start because of the tumblers in the locking mechanism arent in the right places? Who knows? I'll see for sure when the new ignition switch comes in. He (the seller) said I can return it if I cant get it to run. It may seem shady to all of you but this was a legit sale. He was just unloading his inventory before the soon to be Ex wife puts the pinch on him. Thanks for the help guys =) I guess if the ignition switch dont work i'll take it in and get raped for the diagnosis =(
Old Feb 17, 2011 | 12:12 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
As stated before, If it's in gear it will not start unless your holding the brakes. Be sure of that. I've been on the trail before and shut it down in gear and later can't restart it. And the DUH! kicks in. Makes you feel pretty stupid sometimes. LOL
Old Feb 17, 2011 | 05:17 PM
HaydenS's Avatar
I found the problem. There was a 9volt battery behind the dashboard that I took out and the machine fired right up. Thank you all for your help
GregM
Mar 6, 2018 06:53 AM
GearheadMOM
STOLEN
Aug 8, 2015 11:47 AM
panicmanic
Aug 3, 2015 10:49 AM
ltrmc02
Jul 22, 2015 04:50 AM
Jul 7, 2015 11:00 PM
