LT80 Oil Pump
Old Feb 18, 2011 | 12:10 AM
Konner_Bug's Avatar
Default LT80 Oil Pump
I got my 7yr. old Son a 2002 Suzuki LT80 3 weeks ago & have a few questions: 1.- Is the oil fill cap for the crank case under the plasic over the head & where is the oil level check bolt? 2.- I wanted to do away with the oil injection & instead of pullin the side cover off I just took the oil pump off & removed the plastic piece that is under the oil pump. It has a gear on the end of it & a slot on the top where the oil pump fits in. Will this be ok? I capped the port on the carb where the oil line went, put a screw in the oil line runnin from the pump to the carb & removed the oil tank. I took the carb off, cleand it as it had been sittin for 2yrs. 3.- What is a good premix ratio & how do I figure how much 2 cycle oil to put in a gallon of gas to get the correct ratio? 4.- The rear brakes work but the brake pedal won't spring back up after pushin it, you have to pull it back up with your foot. How do I go about fixin this? Thank you in advance.
Old Feb 18, 2011 | 07:44 AM
LT80's Avatar
LT80 Expert
It's a 2 stroke, no oil in crankcase. There is a gearbox. you check that level by removing a bolt by the front sprocket. Oil should weep out if full.
Oil inj pump:: It's fine for now but when you service the clutchs you can leave out the lil plastic thing that drives the pump.
32:1 for mix ratio. Read the container for proper amounts.
Brakes:: The cable may need lubed. Some ppl add a extra spring back there.
Old Feb 18, 2011 | 08:27 AM
Konner_Bug's Avatar
No oil in the crankcase? I feel like an idiot as I'm a retired/disabled ASE forklift mechanic/ ex-drag racer of 20+ years & am askin dumb questions about a 4-wheeler. This is the first one I have ever touched so I'm a little cautious. I did lube the brake cable & the two springs that return the pedal seem good. I thought about puttin an extra spring on the back but wanted to ask first. One question though, How does the rod bearing get oiled if there is no oil in the crankcase? I'm gonna tear the complete 4-wheeler down this comin winter just to see how everything operates but I need to keep it runnin decent untill then as my Son loves it. Ohh, what is the purpose of the reeds & where are they located? I don't have a service manual but am orderin one. Thanks.
Old Feb 18, 2011 | 12:07 PM
LT80's Avatar
LT80 Expert
Hehe. No dumb questions.
The rod and main bearings get lubricated with the fuel/oil mixture.
The reed cage is behind the carburator. The reed acts like a valve would in a 4 stroke. When the piston goes up it draws air in which opens the reed. When the piston goes down the reed closes and the crankcase builds pressure which fills the cylinder with fresh mix.
A guy on ebay sells a manual on CD for like 10 bucks.
Old Nov 5, 2011 | 02:01 PM
TCNJ's Avatar
Default Oil?
I agree it's odd, every 2 stroke I have ever owned has had gear oil in the crankcase to coat the clutch and other internals. This is the only atv I have ever seen set up this way, it's more like an air cooled weed wacker than an atv engine.
What oil do you recomend for the gearcase? is a product like Bel-ray gear saver good or do you use something more like conventional 10-30w motor oil?
Old Nov 5, 2011 | 03:50 PM
LT80's Avatar
LT80 Expert
It's not odd at all. Yor previous 2 strokes did not have oil in the crankcase. Thay had oil in the gearbox...Just like a LT80. It just that the LT80's gearbox is 6 inches away.
Gear lube is good.
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
rockinkgin
Sep 25, 2015 01:52 PM
Sw00p
Sep 24, 2015 02:50 PM
