ball bearing in my cvt cover
Old Feb 18, 2011 | 11:09 AM
wayout's Avatar
Default ball bearing in my cvt cover
here lately ever once and while i'll hear something in my cvt cover that sounds like ball bearing bouncing around inside the cover of my transmission,or at least that's where it sounds like it coming from,i changed my cover bearing awhile back,any ideas on what this might be.............
Old Feb 18, 2011 | 12:51 PM
HMT Racing's Avatar
What type of ATV are you referring to??
Old Feb 18, 2011 | 02:48 PM
wayout's Avatar
it's a 2008 sportsman 400 ho
Old Feb 19, 2011 | 12:12 AM
Jmuddin284's Avatar
the only ball bearings I know of on that side would be out of your crankshaft bearings... you might want to take the clutch cover off and take a peek see and see what it might be.. it could be your clutch belt fraying and once in a while one of the stings could be getting loose and hitting the cover with a knot in it or part of the belt still attached slinging around and hitting it
Old Feb 19, 2011 | 08:28 AM
wayout's Avatar
thanks,never though of that,if it would be the bearing you would thank it would be more than one hitting the cover, i'll check that out,thanks.............
Old Feb 19, 2011 | 09:15 AM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
My guess also ......would be a bad belt.............If you had a piece of a ball bearing in there I think you would know it.........The whole quad would be shaking due to the extra play in the shaft.............Caper.............
Old Feb 21, 2011 | 03:16 PM
wayout's Avatar
i was talking about the bearing in the cvt cover,i changed it awhile back,just thought it might of broke and one of the bearing was bouncing around ever now and again,i live here in wv.and i keep it outside,it's been cold and snowy here,i was just trying to get some ideas,before i tore into it,i know i'm going to have to take the cvt cover off before i know anything,seems like it might be slipping a little now,probably is the belt,it has about 2,500 miles on it, never rode hard,10 mph most of the time,maybe the heat from slow ridding did it,well i'll soon find out,as soon as it's warms up a little............
2quiker
Mar 22, 2022 08:36 PM
fordfaithful21
Dec 7, 2015 05:52 PM
89Lt250r
Sep 7, 2015 07:53 PM
antiguogrumete
Sep 5, 2015 03:41 AM
Canamaniac!
Sep 4, 2015 06:44 PM
