07 Sportsman 500
Old Feb 22, 2011 | 11:21 AM
Nailbender1's Avatar
Default 07 Sportsman 500
efi and it sometimes stalls. I have 1000 miles on it. Do you guys ever run enjector cleaner through these things?
Old Feb 22, 2011 | 12:13 PM
One thing you want to do is check inside the throttle housing to make sure there is at least 1/16th of an inch gap. If they are making contact the quad will stall. Had this problem on an ATP 500 my son previously owned. Not an EFI but they still use the same throttle housing.
Old Feb 22, 2011 | 12:57 PM
Ill check when i get home. Thanks for the help.
Old Feb 22, 2011 | 03:35 PM
reno82's Avatar
Check your battery cables. Mine was stumbling and stalling, ended up being a loose - cable
Old Feb 22, 2011 | 04:57 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Probably not your problem but just for routine, try adding seafoam to your gas. Helps stabilize gas, and keep fuel system clean. I use it on nearly everything. Good stuff!
Old Feb 22, 2011 | 05:35 PM
Kerbbirds's Avatar
ditto on the seafoam, only additive youll ever need as mentioned check the slack in electronic throttle control, should have 1/8 inch at thumb throttle
Old Feb 22, 2011 | 08:34 PM
pajamie's Avatar
fighting the same problem with mine.. tried seafoam.. fresh gas.. changed plug..
Thinking its time to take it to the shop and stop pulling my hair out over it..
Old Feb 22, 2011 | 11:49 PM
GTSnoRacer's Avatar
I had a similar problem on my 07 500 EFI with random stalling and rough running (almost like a limp mode) and turned out to be a MAP sensor.
Old Feb 23, 2011 | 10:37 AM
TLC's Avatar
TLC
Polaris ATV Thumb Throttle Maintenance Tips: Polaris ATV Maintenance & Repair Tips | eHow.com
Good chance its this, very common.
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
