82 200E running problems
Old Feb 26, 2011 | 02:41 PM
willows's Avatar
Default 82 200E running problems
My 82 200E will only idle well with the mixture screw turned all the way in. Also misses when revving up a little in neutral.
Any ideas of what to look for?
Old Feb 26, 2011 | 02:48 PM
RighteousEX's Avatar
Did you take the carb off and clean it?
Old Feb 26, 2011 | 06:49 PM
willows's Avatar
Carby was a new ebay one about 3months ago. Have just cleaned it and used silicone around the o-rings on the inlet manifold. Still has the problem.
Old Apr 7, 2011 | 06:58 PM
SMFREY's Avatar
Not sure if you have tried this as yet but I would lower the needle in the carb.
this will lean the motor and should allow to run better.
Good luck
Ray
wildbill59
Jun 9, 2015 02:28 AM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
blaze_master
May 26, 2015 11:18 AM
