i have an 05 Polaris sportsman 400 thats stuck in 4x4
Old Mar 2, 2011 | 12:37 PM
matt zoltan's Avatar
Default i have an 05 Polaris sportsman 400 thats stuck in 4x4
i can tell u is that on the speedometer it shows that the 4wd is on and even if i go to flip the switch to 2wd
it still shows that 4wd is on which it sadly is i can see the prop shaft runing from the rear transmition to the front
moving
Old Mar 2, 2011 | 01:36 PM
kcaves's Avatar
actually sounds like the roll cage in the front diff is broken, have to tear apart the front diff and check
Old Mar 2, 2011 | 02:09 PM
it might be that idk id like to here more things befor i go trying to fix it
Old Mar 2, 2011 | 03:02 PM
kcaves's Avatar
find the wires coming out of the diff and follow them up under the cover beneath the headlight pod and disconnect the plug right there, if it stays in awd after u disconnect all the power to it, then the roll cage is ur problem, its a common problem with that year machine
Old Mar 2, 2011 | 04:47 PM
switzomatic's Avatar
Ditto on kcaves post!
Old Mar 2, 2011 | 07:39 PM
ramman67's Avatar
Default shaft
The prop shaft that goes from the transmission to the front gear case will always turn.It will turn no matter if you are in two wheel drive or awd.If your awd icon in the speedo is on even when your in two wheel drive then its most likely the awd switch or the speedo its self is the problem then.Like Kcaves said unplug wire if problem goes away then its electrical then.
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
sara durrant
Jul 6, 2015 05:32 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
