polaris trail boss 4x4 issue
Old Mar 7, 2011 | 11:43 AM
Cheezstik's Avatar
Default polaris trail boss 4x4 issue
a couple questions,
i have a 1989 polaris trail boss 4x4.the 4x4 shaft turns on the front but is not transmitting power to the front wheels...whats wrong?
what kind of oil does it use?
also where could i find a free online manual for it?
Old Mar 7, 2011 | 06:00 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Originally Posted by Cheezstik
a couple questions,
welcome to the forum. sounds like the hubs aren't getting power. is the awd light on when you push awd button? it should be a 2 stroke so any good 2 stroke oil will work depending whats already in there.
Old Mar 7, 2011 | 06:48 PM
Cheezstik's Avatar
the 4x4 is on all the time apparently because whenever i flip the switch either way, it stays in 4x4...so, how could i reattach it to the hub?
Old Mar 8, 2011 | 05:58 PM
randyneff6971's Avatar
if your asking what kind of oil does the quad take? it takes any 2 stroke oil for oil injection systems. if your asking what kind of oil does the 4wd take? it takes Polaris Demand drive fluid. for the front hubs. as for power getting to the hubs take off the front plastic to expose the power block find the 2 small wires going to the hub (2 to the right side and 2 to the left side) first make sure there is power 12volts at the connections with the awd switch turned on. if there is power there, then take the front hub apart to expose the magnetic coil still with the switch in AWD place a small screwdriver on the coil you will feel a magnetic pull if you don`t try and trace the small wires there more than likely a brake in them. If you get a magnetic pull at the coil you 4wd should be working fine. Make sure the armature plate is good and reinstall the components to spec use demand drive fluid in the hubs some say type f tranny fluid will work personally you should use polaris fluid.
Old Mar 9, 2011 | 10:53 AM
Cheezstik's Avatar
Thanks! i'll try that... does anyone have a list of all the plastics that would fit an '89 trailboss?
Old Mar 9, 2011 | 11:09 AM
TLC's Avatar
TLC
Here is a good link on the front HUB drive AWD system. http://www.atvtime.com/phpBB2/viewto...003&pc_t=12521
wildbill59
Jun 20, 2015 02:26 PM
PolarisPower500
May 17, 2015 02:28 PM
EXtreme
Sep 10, 1999 12:54 PM
Matt24
Aug 3, 1999 07:46 PM
