water leak
Old Mar 12, 2011 | 09:00 PM
rccub23's Avatar
Default water leak
1996 polaris sportsman 500. i have water leaking from where the pull start housing bolts to the engine. any thoughts.
Old Mar 12, 2011 | 09:19 PM
kcaves's Avatar
theres a drain plug at the bottom, take that out and let everything dry out really good, make sure ur handle is seated all the way when ur riding, might even need to add a little silicon to make sure water doesn't get in there anymore
Old Mar 13, 2011 | 08:14 AM
Kerbbirds's Avatar
I would remove recoil housing and see how rusted everything inside is, clean it up then re=seal everything
Old Mar 13, 2011 | 10:40 AM
rccub23's Avatar
thanks for the quick replys. i will clean it up and seal. thanks again.
Old Mar 13, 2011 | 11:04 PM
bjones12's Avatar
On some models Polaris put a weep hole between the pull start and the crank case. If your model has a weep hole then it is a good chance that the water seal has gone bad.
exmotocrosser
Sep 13, 2019 06:12 AM
Alex G.
Sep 11, 2017 11:38 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
