02 sportsman 400 front hubs lube?
Old Mar 13, 2011 | 07:13 AM
lawns90's Avatar
Default 02 sportsman 400 front hubs lube?
I have a 02 sportsman 400 4x4 and want to change the fluid in the front
hubs. I have read I can use a 80-90 w gear lube gl5? Is this true? How
much fluid do i add and how do i do it. Thank You!
Old Mar 13, 2011 | 07:32 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
you need the correct hub fluid to make them work correctly and not to have issues later on. ther is an allen screw on the hub side that you take out and i think turn it to the 3 oclock position to fill(not 100% sure). maybe some one w/ the older hubs style can say on the filling for sure.
Old Mar 13, 2011 | 07:50 AM
Kerbbirds's Avatar
use the demand drive fluid 80-90 would be way too thick
Old Mar 13, 2011 | 11:34 AM
Jocko's Avatar
The first thing you should do is go buy yourself a good repair manual like Clymer.
Don't put 80-90W in your front hubs. You can alternatively use ATF Type F transmission fluid, but why not just go with the best? Use the Polaris OEM demand drive fluid.
Rotate to either 4 or 8 O'clock and fluid should just trickle out when it's the correct level.
Old Mar 20, 2011 | 03:40 PM
sumpter12's Avatar
I have been using ATF tranny fluid for several years with no issues.
Old Mar 20, 2011 | 05:47 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
Are you talking about the actual hubs out at the wheels or the front differential/gear box? You need the hub fluid out at the wheel hubs. You can use about any good 80/90 for the front diff. That's one of the things I really miss about the older bikes. Not as sensitive and built much stronger IMO.
Jmuddin284
Jan 19, 2026 07:16 AM
ranvette
Jul 4, 2015 06:13 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
Mphillips
Jul 2, 2015 07:20 PM
