how to check warning lights???
Old Mar 22, 2011 | 11:44 PM
bigcam400's Avatar
Default how to check warning lights???
95 xplorer,should be same as sportsman,..only one ive seen work is the reverse light??? can these lil light blocks be tested with ohm meter??
Old Mar 23, 2011 | 01:52 PM
Check under pod for connections to the three sealed bulbs, 4040052,4040053,and 4040054 bulb #'s. Does Hi beam light work? could be just burnt out bulbs. Common brown ground wires to all three,with blue hot wire to high beam,red to hot I think and a purple wire? can use a simple test light or ohm meter on hi beam hot wire with switch on,should have voltage,if light not on replace the bulb,just pops out of pod. You can apply voltage to the others and just touch a brown wire for ground,should show good or bad. OPT
Old Mar 23, 2011 | 02:10 PM
bigcam400's Avatar
thanks for the info!
bzdok1234
30
Feb 23, 2016 01:55 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
