06 sportsman 700, right front wheel not engaging in AWD
If your sitting on the atv, the wheel on the right is not engaging in AWD. There is nothing wrong with the axle, the splines on the axle and the diff are not rounded. I have replaced the fluid. I pulled the diff today and took it apart expecting to see a busted roll cage, but everything inside looks fairly good. There is wear on the armature plate where that little copper piece rubs on it. I put my ohm meter on the wire coming out of the diff and couldn't get anything out of it, I'm not sure if that means anything?
Does anyone know what might be the problem, or anything I need to look for? I can take pictures of the inside of the diff if needed.
I didn't check the splines on the hub, but I'm not sure how I would do that because I left the axle nut on when I pulled the diff, so I'm not sure how I would loosen that nut?
Before I took anything apart, I shook the axle and didn't feel any play in it. I also jacked the front up and spun the wheel and nothing was binding or anything.
Is there any reason why I would be getting no resistance from the coil wiring?
Thats a good idea, but will the bar mess up the threads on the wheel studs? I can't believe the rims on this thing don't have a center cap, but it is what it is I guess!
you could jack up the front and put a pipe wrench on the cv axle(on the steel shaft part of course
) and try to spin the tire easy then as hard as you can and if the axle doesn't spin and the tire does then stripped splines
UPLou
Jun 7, 2015 09:42 AM
