polaris hawkeye 4x4 front end
Old Mar 28, 2011 | 12:26 PM
suthernasitgets87's Avatar
Default polaris hawkeye 4x4 front end
Can anyone tell me where to find a used front end or atleast parts for one? My hawkeye 4x4 300, needs a new front end.
Its a 2007. And does anyone know if i can use a different size front end or does it have to be from a 300. PLEASE LET ME KNOW.
Old Mar 28, 2011 | 01:21 PM
The Polaris Hawkeye was made by AEON,you can check ebay for used parts, also Cheap Cycle parts which are pretty much cheaper than oem,plus other posters probably can help more. OPT
What parts are needed???
Old Mar 28, 2011 | 06:31 PM
TennesseeTider's Avatar
Hawkeyes were made in Minnesota. Phoenix and Sawtooth were the ones made by Aeon.
Old Mar 28, 2011 | 08:20 PM
Still AEON frame, suspension,gear case, clutches etc. Plus the updated front hubs I had to replace under safety bulletin were in Aeon marked boxes. If original poster didn't have update on steering post and tougher hubs,could be part of his problem,unless was wrecked??? OPT
Old Mar 28, 2011 | 10:48 PM
HawkeyeRider's Avatar
Try doing a Google search for ATV salvage parts, or ebay. The Hawkeye was introduced as a totally new model...so yea it's a pretty good bet the frame stuff and a majority of the parts will have to come off another Hawkeye. Good Luck.
Old Mar 29, 2011 | 12:18 AM
Default in reply to your comments
What exactly is the problem is unknown, but i think is....
Im almost poitive that i need the entire frnt end, the casing, the gears, axels, booties everything
There are 2 major cracks on the casing. With my atv, the steering is connected to the differential casing, around the top of where is connects, is cracked almost all the way around, and then at the botton, its cracked nearly all the way around.
We drained the gear oil out, and metal shardes came out, now the 4wd isnt working... and if you flip the switch to 4wd, it blows the fuse.
I havent taken apart the front end yet, but my assumption is, an entire new front end is needed.
Let me know what yall think.
Old Mar 29, 2011 | 09:59 AM
When you say front end are you talking about the FRONT GEAR CASE (differential) only??? By your post,sounds like it,plus if case is cracked,no awd,etc!! Then yes,it probably needs a new gear case assy. OPT
neilbedwell
Nov 10, 2018 11:02 AM
WilliamBos
Sep 30, 2015 08:08 AM
txkevin
Sep 21, 2015 02:02 PM
bonanza 440
Jun 26, 2015 10:01 PM
yellowpolaris
Jun 21, 2015 11:13 AM
