2004 700 EFI Plugs
Old Mar 31, 2011 | 08:41 AM
NEK VT's Avatar
Default 2004 700 EFI Plugs
The plugs on my 2004 700 EFI look really hard to get at. Whats the best way to get at them? Any tricks / tips?
Thanks
Old Mar 31, 2011 | 11:17 AM
The easiest way for me was to remove both side panels,the right plug is fairly easy to get to,the left one is the b*****h! but I just reached across and was able to replace left plug from the right side! Easier if you can pull vent hose out of the way. BUT I had a lift and worked at chest level(makes a difference) OPT
Old Mar 31, 2011 | 11:33 AM
NEK VT's Avatar
Default Plugs
Also The store did not have Champion plugs so they crossed them and gave me BKR7E NGK Plugs. Any experience with these in this machien? I will look at my shop manual for proper gap.
Old Mar 31, 2011 | 03:34 PM
JCDEYO25's Avatar
My opinion is that the NGK's are much better...
John
Old Mar 31, 2011 | 03:49 PM
readymixer169's Avatar
Of all the things I've lost in life, I think I miss my mind the most!
I thought all sportsmans called for the NGK plugs as the oem suggested replacement. I've always thought the NGK's were better for power sports equipment anyhow.
Old Mar 31, 2011 | 03:57 PM
NEK VT's Avatar
Default Plugs
No the chop manual, lists a Champion plug number.
Old Mar 31, 2011 | 04:16 PM
kcaves's Avatar
go with NGK, champions suck
Old Mar 31, 2011 | 04:31 PM
DITTO!!! Champions are good for lawn mowers and weed eaters . 2002 700's had champions and had problem with em fouling out! I changed to BKR7ES from the very start and didn't have any more problems! OPT
Old Apr 1, 2011 | 04:21 AM
switzomatic's Avatar
I agree the NGK's are a much better plug. Also be sure when you pull the plug wires off to blow the holes out with air before removing to get any debri out of there.
Old Apr 1, 2011 | 05:42 AM
Kerbbirds's Avatar
p[ut some dielectric grease in the wire boots before you put them back on
COFatboy
May 2, 2020 12:06 AM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
velcro7279
Aug 24, 2015 01:15 PM
Captjay
Jul 23, 2015 12:33 PM
