EZ question...this time!
Old Apr 5, 2011 | 05:17 PM
jeepcrazy's Avatar
Default EZ question...this time!
Hi guys.purchased 2 used 2001 trailblazer 250's.want to service both.already swapped air and fuel filters.is the only oil filter the small one that is in line from injection pump to carb?what to do with crankcase?(type of fluid,amount and where is drain?)thanks in advance.
Old Apr 5, 2011 | 05:52 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
these are 2 storke bikes. there is no oil in the crankcase. the oil in thetank in front is the lube for the engine.
Old Apr 5, 2011 | 06:45 PM
From the oil tank to the oil pump there is a small filter that can be changed if you like. Be sure to bleed the pump after filter change to remove any air (10 mm bolt on top of oil pump) just open up a little until all bubbles are gone. Check condition of small hose from pump to cylinder. Not necessary to change 2-stoke oil,just top off tank holds 2 quarts,will go through several tanks of gas before needing more oil. As mentioned this is the engine oil,none in the crankcase. The separate gear case takes Polaris gear case oil or suitable oil for chain drive gear cases. OPT
Old Apr 5, 2011 | 09:55 PM
Jmuddin284's Avatar
is there no counterbalance on the 250? I know I have to have 4oz of motor oil in my 400 for this. The 250's must not have this
Old Apr 5, 2011 | 10:00 PM
NO counter balancer,just a crankshaft.
Old Apr 6, 2011 | 04:54 PM
jeepcrazy's Avatar
sorry!i did mean gear case,not crankcase when i asked earlier.found drain plug underneath.about how much does it hold?
Old Apr 6, 2011 | 05:13 PM
Overdrive's Avatar
18ozs. Use Castrol Syntec 5w50 and you will not have any trouble with the chain in the trans.
Old Apr 6, 2011 | 08:45 PM
Jmuddin284's Avatar
I can't say yea or nea on the 5w50 but, if that's the equal to the $14 a quart polaris AGL (polaris recommended) then go for it and once I run out of my quart next year that's what I'll use too. Cause I know it's much cheaper than the stuff I've been using from polaris
Sjrpp
May 2, 2023 03:59 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
