2005 eton viper jr
Old Apr 6, 2011 | 10:52 PM
jeremy 031's Avatar
Default 2005 eton viper jr
my carberator keeps flooding. ive already replaced all the jets and cleaned the carberator and its still doing the same thing. the carberator kit came with an O ring and i have no clue where it needs to be. i think that should fix my problem. does anybody know?
Old Apr 7, 2011 | 06:59 AM
Jaster94's Avatar
your float is sticking, its position is false and bringing in fuel. also check your crankcase oil for gasoline contamination.
Old Apr 7, 2011 | 11:15 PM
LynnEdwards's Avatar
Electrical Expert
Is the O-ring really small?
I don't know anything about eton carburetors, but I've worked on other small enigne carburetors where the float needle valve seats into an o-ring pressed into the fuel inlet hole. That little o-ring (if you have one) flys out without a trace when blowing passages out with compressed air.
Again I don't know about your carburetor, but just in case it might be your problem I thought I would mention it.
By flooding I think you mean that fuel comes out the overflow? If so I agree with Jaster94. Your Float needle valve is leaking.
Old Apr 8, 2011 | 10:56 PM
arcticjeff73's Avatar
I have had these etons and sometimes u have to bend the tab that pushes up on the needle valve so it closes sooner but don't bend it too much.
Old Apr 12, 2011 | 10:22 AM
capebreton1967's Avatar
Also examine the "Float" assembly for holes or most likely cracks. If the Float fills internally with even a small amount of Fuel it won't operate properly enough to stop the fuel flow past the valve.
Good luck.
flyin-lowe
Dec 1, 2017 03:18 AM
salixair
Nov 3, 2015 08:25 AM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
Brandon400
Sep 5, 2015 08:44 PM
