Secondary settings
Old Apr 7, 2011 | 03:07 PM
Scrambler00's Avatar
Cool Secondary settings
Got a 02 scrambler 400, my sig is accurate, has aaen green primary spring, blue secondary, I'm venturing into fine tuning,
Questions: secondary is set at 2:2
From what I have read 1:1 is for more topend, and 2:3 is for more low end
I'm gonna try 1:1 tom, if I don't like it what's a good way to find what's best? And would it matter what hole u changed up, like the helix hole at 1 and the base at 2?
Also un related carb question, when adjust needle position what way is richen and to lean?
Thanks in advance u guys
Old Apr 7, 2011 | 06:57 PM
Kerbbirds's Avatar
kinda depends on whatn elevation your at, at 5000 ft in wyoming I set stock secondary clutchesin hole 1 on the sheaves and hole 2 on the helix, have tried other settings but this one works best here
Old Apr 8, 2011 | 11:36 AM
Post
update: so after some research on how to preload the dam spring, i tried out 1:1, lost top end with this option and didnt notice anything else other then the loss, topped at 103 km/h without winding it right out
tried the 2:3 setting, i liked this one, seemed to accelerate harder and faster.... topped at 113km/h or 70mph
tried the 2:2, this is what it was on before seemed very peppy but not a whole lot on top, this put me back to my 107 aka 67mph, while i had the clutch apart i put in new buttons, and actually switched housings and helixs with a secondary from another scrambler clutch, my helix was very worn,
QUESTION: will running it at 2:3 have any negative effects? i tried it on steep hills and seemed as good as before, can power all 4 wheels mad spin from a stop. MY altitude is approx 250-1000ft
Old Apr 8, 2011 | 03:01 PM
woodsidewarrior's Avatar
Lower the clip to richen raise clip to lean
Old Apr 8, 2011 | 06:37 PM
ok thanks for the tip, will now master the pilot/ idle circuit haha..... anyone know if the setting 2:3 setting has any draw backs?
Johnny Mac
Aug 15, 2019 03:13 PM
Robinhood
Dec 26, 2015 10:28 AM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
IMLN
Sep 28, 2015 03:32 PM
