kfx400 Boy did I mess up. What can I do?
Old Apr 11, 2011 | 09:49 PM
slater25's Avatar
Default kfx400 Boy did I mess up. What can I do?
04 kfx 400. Im replaceing a timing chain and gear. I took the clutch off than I started to take the crank nut off so I can remove the timing gear.
Guess what I did???????????? Anyone ?????????? yup, I put a inpack on the nut and turned it counter clock wise till it started to move and than it moved and moved. Well I did not know that it was a left hand thread but I do now. So the nut was stuck on the crank with no hope of comeing off, it just spends and spends. I got the air grinder out and started cutting, boy was I ever careful. I got the nut off with out hitting the crank.
After looking at the treads on the crank they dont look to bad but one thread in the middle is a little messed up.
I do not want to split the case to install a new crank so what are my options? I have ordered a new nut and I hope that it will just go on and every thing will be fine. What do you all think I should do ? No smart A_ _ 's please. I feel like crap about this.
Old Apr 11, 2011 | 09:54 PM
atvkiller's Avatar
well your best bet would be to get a die to you size and run it down the threads to clean them up and to fix the damaged ones a easy and quick fix id done the same you can ever tell by the looks what way it goes
Old Apr 11, 2011 | 10:00 PM
slater25's Avatar
Default sounds good
That is what I have planed to do. After I get the new nut I will try to size it up to get the die I need to chase it. Any one know what size die I need? Thanks for your input.
Old Apr 11, 2011 | 10:04 PM
atvkiller's Avatar
not off hand i dont think i have any of those motors at work i take atv motors apart every day for rebuilds and im not sure what size it could be but il check tomorrow when im there for ya your best bet might be just to wait or check on line for it
Old Apr 11, 2011 | 10:13 PM
slater25's Avatar
Default Thats cool
Thats's cool, I have checked online but I cant find any info on the subject. Any info you can get would be great. I will wait to hear from you. Thanks again.
Old Apr 12, 2011 | 12:24 AM
Doctorturbo's Avatar
GOT BOOST!
Another thing I have done if you have enough room is washer or double washer in front of the nut. This will get you out of the area of boogered up threads. Also might be a good idea to blue loctite it.
Old Apr 12, 2011 | 03:37 AM
cncpro's Avatar
Another possibility would be a thread file if the shaft is only slightly damaged. It's hard to believe that only 1 thread is bad as you said above but if that's really the case you may be able to clean off any high spots with this...
Thread Repair File - Metric - General Tools & Instruments
Note that it has multiple thread pitches on it so you would hopefully have one that matches the shaft...
Old Apr 12, 2011 | 06:21 PM
slater25's Avatar
Default cool
Never saw or heard of this type of tool. This is way cool, not sure how it works. The middle thread looks to sit lower than the other threads that is why I said it was messed up. Thanks for your idea, I love it when people try to help others like this. Thanks again.
Old Apr 18, 2011 | 08:07 PM
slater25's Avatar
Cool hello.
Like so many post, most people never return after finding out their problem to let you know how it went. Thats not me. I bought the thread file and it works great. I got everything back together and everything is working as it should. Im haveing a carb issue but I ordered a jet kit and I will keep you posted on how that works out.
Thanks for all your help guys. Its people like you that save poor people like my self tons of money.
Old Apr 18, 2011 | 11:24 PM
GOT BOOST!
Glad it turned out good for you. And good for you for doing your own work!!!
Get the carb fixed and go have fun!!
