oil on inside of front wheel
Old Apr 11, 2011 | 09:57 PM
bigcam400's Avatar
Default oil on inside of front wheel
was out in the shop pittlin with the race car an noticed what looked like ATF on the inside lip of front wheel of my 95 xplorer 4x4,...no puddle or streeks down the tire side wall,..spect its a hub sill going bad,...if so how hard is it to replace??
Old Apr 12, 2011 | 01:13 AM
mrtwostroke's Avatar
As a quick fix I have just added oil, before a ride. Then next time it sits no oil.
I think it justs gets a little dirt under a seal, causes a leak.
It's a actually a pretty easy fix to replace the seal. The seal on the strut is a little more involved, but the hub seal in more common to see leak from. I find anyway
Old Apr 12, 2011 | 07:29 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
maybe age of seal or like mentioned dirt or some thing got in there. shouldn't be too hard to replace.
Old Apr 13, 2011 | 04:28 PM
01sportsmna500's Avatar
Take it apart yourselfm if everything is working fine its a pretty cheap fix. Check the sleeve that the seal rides on, on the strut. If its grooved or worn, you can replace this also when you change the seal. They are just CR seals and a good bearing supplier can get them real cheap.
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
Reactant
Jul 16, 2015 10:29 PM
JackTheKing
Jul 14, 2015 09:09 PM
tporath
Jul 11, 2015 12:31 PM
