clutch question
Old Apr 17, 2011 | 11:16 AM
jeremyd's Avatar
Default clutch question
hey I have looked for abut a half an hour now and I can't frind my answer to my question... it I change the weights and spring in my primary clutch do I have to change the secondery? and another question... what do the weights do exactly?
Old Apr 17, 2011 | 05:33 PM
Scrambler00's Avatar
I dont think you HAVEto change ur secondary spring BUT it would be a good idea too, Quoted from AAEN site
"Primary Springs - Changing springs will greatly affect both your engagement stall RPM and your top end shift speed. Higher preload produces higher stall speed at belt engagement. Higher full shift load gives you more RPM on top end. "
Your weights are explained here "Weights - Heavier flyweights give aggressive performance on normal trails. Lighter flyweights keep RPM up in heavy mud and sand pulling. "
Sec spring " Affect shift speed and backshift. Stiffer springs have higher shift RPM and quicker backshift."
when i did my atv pipe and matching clutch kit, i got a primary and secondary spring, i didnt mess with my weights though hope this helps
Aaen Performance - Polaris ATV Accessories
Old Apr 18, 2011 | 10:30 AM
jeremyd's Avatar
I have to take mine in to get the ebs bushing replaced so it mght be best to get the dealer to do it for me so how much shouldI expect to pay?
Old Apr 18, 2011 | 02:38 PM
Shop labor depends on where you are AND who is doing it( A dealership or just a repair shop) can range from 65- to over 100 bucks hourly rate. I would say between and hour to an hour and half labor,IF you bring the clutch in. Just depends on what all you have done. If they estimate more than two hrs,FIND another shop! OPT
ghost civic
Jan 15, 2020 07:43 AM
4464
Aug 21, 2015 01:46 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
