2001 Polaris Sportsman 500 4wd works sometimes
Old Apr 19, 2011 | 10:13 AM
Tinner's Avatar
Default 2001 Polaris Sportsman 500 4wd works sometimes
I have a 2001 Sportsman. Lately this thing goes into 4wd....sometimes. It sat for a few years in a shed after an a-arm broke. It seems to have some gremlins now. I got it running again and now the 4wd is not working all the time when I want it to. Any thoughts on this?? Thanks
Old Apr 19, 2011 | 10:21 AM
TLC's Avatar
TLC
Change the hub fluids first of, here a good link on the AWD set up. ATV Time :: View topic - Polaris Demand Drive Hub Q&A Picture Guide to Service
Old Apr 19, 2011 | 06:50 PM
ramman67's Avatar
Default 4wd
Is your battery good? Has to have a good 12 volt battery in it for 4wd to work properly.
Old Apr 19, 2011 | 10:20 PM
TLC's Avatar
TLC
I rode mine for a month with a dead battery without ill effects, I think you only need a good battery if the model has a ECM brain box (2004.5 and up), unlike the older makes.
Old Apr 20, 2011 | 05:54 AM
Kerbbirds's Avatar
wiggle and move the shifter around , see if that makes the awd come and go, might be the shiftrer switch
Old Apr 20, 2011 | 01:09 PM
ramman67's Avatar
Default 4wd
It needs a good battery in it for 4wd to work right. Does the 4wd light on your throttle light up when machines in high or low and 4wd switch is on?
Old Apr 21, 2011 | 07:32 AM
TLC's Avatar
TLC
I quess it was all in my imagination that my AWD worked fine with a dead battery for a entire month on my 2001 model.
Old Apr 21, 2011 | 06:37 PM
ramman67's Avatar
Default awd
I guess i will take all our service manuals at the dealership i work at and under 4wd trouble shooting mark out number one question.Does machine have a good 12 volt battery.Maybe yours worked fine but we have had many customers with bad battery and no 4wd replace battery and 4wd works fine again.
Old Apr 22, 2011 | 11:36 AM
TLC's Avatar
TLC
Like I said maybe the 2004.5 and up with the ECM brain box may need a good battery for the AWD to work but our 97 and 2001 models do not seem to. Our 97 even had a smashed off speedo from a roll over that did not effect the AWD. The speedo must work for the 99 and up models to have AWD so things do change from year to year.
whitty
67
Feb 24, 2021 02:52 PM
skittero
35
Mar 1, 2019 12:39 AM
yellowpolaris
Jun 21, 2015 11:13 AM
Big600twin
14
Jun 16, 2015 09:30 AM
mudhog
Nov 2, 2000 06:22 PM
