Body Plastic woes...
Old Apr 21, 2011 | 08:18 AM
Nugget Shooter's Avatar
Default Body Plastic woes...
Howdy All,
Anyone know of a fix for the broken mounting tabs on the body plastic for my 2006 Sportsman 500? Thinking about epoxy, but will not work on some plastics so hoping someone else has tried successfuly to repair this issue in the past.
Ton of cash to replace the whole rear section so wanting a fix.
Old Apr 22, 2011 | 03:12 AM
switzomatic's Avatar
I've used the two-part epoxy on motorcycle plastic and had good results. Not sure on what the cost would be but you could check around to see if there's any places in your area that do the plastic welding. Ebay would be a good place to look for plastics if you end up having to replace them.
Old Apr 22, 2011 | 09:27 AM
I would also try the JB Weld. Had good success on my son's Renegade with it.
Old Apr 22, 2011 | 10:29 AM
rastegsr's Avatar
Default Plastic repair
Had the same problem on my quad so i went an bought the plastic welding kit from HarborFreight.Go to u tube an type in plastic welding. There are plenty of clips that show how its done. Works really but make sure to imbed the wire mesh
Old Apr 22, 2011 | 01:24 PM
Had not thought of that and I am thinking that is the best option as a starting point. Did you use the airless one?
Old Apr 22, 2011 | 08:59 PM
bigcam400's Avatar
if you know any body that dose auto body repair,..most have gottin good at plastic weilding as all cars haveing so much plastic on them,..be surprized what can be fixed an never show!!
Old Apr 28, 2011 | 08:24 AM
Well thanks for all the advise and final outcome was...
Bought a 20.00 airless plastic welding kit and followed instructions as well as watched a fix on youtube....
Fired that puppy up and in about 20 minutes had all broken plastic repaired!
Plastic welder is the way to go for body repairs and saved me allot of $$ over replacing the part
wendal
Aug 3, 2024 10:03 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
awer1968
Sep 8, 2015 11:02 AM
