Aftermarket Polaris starters 59.00 ???
Old Apr 26, 2011 | 01:31 PM
tahoe700302's Avatar
Default Aftermarket Polaris starters 59.00 ???
The factory starter for my 400 xplorer was quoted at 350.00. I found an atv parts dealer on line ( polarispartsdealer.com) that advertises a starter for 59.00.
Anyone bought an aftermarket starter?
Where do you recommend buying parts online?
I think the factory starter price is a bit out of line. Rope start looks pretty good at that price........
Old Apr 26, 2011 | 02:06 PM
Wenty's Avatar
Is your starter not rebuildable? Most of the time all they needs are brushes and a good cleaning and they're good to go. Easy job.
Either way...rebuildable or not. "DB Electrical" on Ebay has the rebuild kits and starters for about as cheap as your going to find. Pretty good quality for the price.
Wenty
Old Apr 26, 2011 | 02:19 PM
Wenty
I'll check that out. Thanks.
Old Apr 26, 2011 | 08:14 PM
Kerbbirds's Avatar
ditto on DB electric, bought several starters for several makes from them had no problems
Old Apr 30, 2011 | 12:19 AM
bcdudley's Avatar
I would try to clean yours up first. I was in the same position last year and thought I needed a new starter. Since mine was already bad, I figured I had nothing to loose by opening it up and taking a peak.
Once I got in there, I found lots of mud and other garbage. Also, one of the brushes was stuck and not making good contact. After cleaning it out good and spraying a little wd-40 on it, the starter was as good as.... a really old starter, but it worked again and has been working fine for the last year.
It didn't cost my a penny to open it up and even if I did break something, I was already planning on buying a new one anyway, so no big loss.
Old Apr 30, 2011 | 01:32 AM
mrtwostroke's Avatar
buy a rebuild kit from one of the ebay stores. what are they 15 dollars vs. 50 for brushes from polaris. but nothing wrong with the whole starters either.
Old May 1, 2011 | 09:01 PM
trbojet1's Avatar
DB Electrical.......I've purchased a few starters from them and have had no problems.
Jmuddin284
Jan 19, 2026 07:16 AM
Coryco
Jul 6, 2015 07:30 PM
jettman
Jul 6, 2015 12:16 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
