baffled
Old May 2, 2011 | 02:01 PM
habs1954's Avatar
Default baffled
My 2004 sportsman 500 will lose all power everything goes blank on the control panel ,I can simply restart the engine. this happens while I'm moving or when the bike is idling.The problem seems to be getting worse.
Old May 2, 2011 | 03:03 PM
Check simple stuff first: battery connections, check that main fuse(20 amp circuit breaker) in plastic pouch has power on each side of pouch(red wire) ,could be the fuse is corroded,shorting out, shutting off power to machine.( Located past battery and starter solenoid ) Plus could check under pod for any bare wires,bad connections,etc,if above items ok.Plus not a bad idea to use dielectric grease on electrical connectors,any where water could be a problem. Hope this helps OPT
Old May 2, 2011 | 05:31 PM
habs1954's Avatar
Default baffled
Thanks I'll try that. I was also wondering about the ecm.
Old May 2, 2011 | 07:47 PM
Kerbbirds's Avatar
dont think it was part of the ecm recall but you can call dealer with vin number and find out
Old May 3, 2011 | 04:59 AM
habs1954's Avatar
Default baffled
No there is no recall on my ecm.Thanks
Old May 3, 2011 | 05:57 AM
Kerbbirds's Avatar
I have changed the ecm on one that wasnt included, i, same symtoms, OPT can tell y6ou the type I think it wasblack, chinese made box under pod with fins on it
Old May 3, 2011 | 11:11 PM
ladiauctioneer's Avatar
Smile Check...
Do you have a key chain for your key? If the key chain is too big it will catch on the tank and move the key just enough to shut you down.
My cousin had this happen and so did I.
Easy fix
Jason Poulin
Sep 20, 2015 02:49 AM
Bigtwin700
Sep 9, 2015 09:32 AM
Huntingdeer
Aug 23, 2015 12:06 AM
raceware
Jul 30, 2015 06:59 AM
cSchwartz
Jul 12, 2015 07:42 PM
