2007 Polaris 330 carb problem
I have noticed that when i start my 4 wheeler that i have to put it on full choke in hot or cold weather.After letting it run for a few minutes i begin pushing in the choke and the motor begins to stall.Now when i start it i have to leave the choke 2/3 out and keep it reved then engage it into forward.I know this is not good for the motor or tranny so i need some ideas where to start.Thanks.
Ok i do not see any screws on the carb to adjust except for the idle screw at the bottom of carb.There is a cap on the side of the carb that i popped off and there is a c clip holding onto a threaded bolt (it looks like).I did not pull off the c clip and check it out yet i wanted to ask you if this is the richen screw.Also when i start the engine and apply choke the engine spits a little and backfires a little.If i get it richened will this go away?Thanks for all your help.
