2003 Honda Recon rear axle bearing making a noise
Old May 12, 2011 | 07:52 PM
Hog Hunter's Avatar
Default 2003 Honda Recon rear axle bearing making a noise
Hey guys my 2003 recon left rear axle (seated facing forward) bearing is squeaking. I greased it and it kind of went away ,but if I turn it hard or ride it for 10 minutes it starts to squeak. After if you feel it ,it is warm to the touch. Should I grease it more ,and see if it gets better ,or replace it. Is it hard to replace any hints how to replace it?
Thanks
Old May 12, 2011 | 09:44 PM
budedm's Avatar
Replace it. They are not greaseable. Not sure of the procedure though.
Old May 12, 2011 | 09:47 PM
2006dvx400's Avatar
well is there play in the axle if there is no play i wouldnt worry to much about it but if there is and you want to replace it its going to be like 60$ in parts.
Old May 12, 2011 | 10:00 PM
420Pimp's Avatar
Its your carrier bearings, replace it asap , before it eats out the housing forcing you to buy a new axle.
Weekend job, couple beers, 2 hours later your ready to roll.
buckshit
Sep 24, 2015 08:49 PM
hoopduerr
Jun 10, 2015 03:00 PM
Jun 10, 2015 12:45 AM
hoopduerr
Jun 1, 2015 08:22 PM
blaze_master
May 26, 2015 11:18 AM
