2004 polaris 700 sportsman vibration
Old May 13, 2011 | 08:41 PM
shadowmax's Avatar
Default 2004 polaris 700 sportsman vibration
I have a 2004 polaris 700 sportsman with a strange vibration. It runs great when you excelerate past a 1/4 throttle, but at an idle and just as you give it gas it vibrates kind of rough. Does anyone know what could cause this, or is that normal. I've never had a atv thats ever done that before, but I've never owned a v twin atv either so I am not sure.
Old May 14, 2011 | 05:55 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
welcome to the forum. first thing is your 700 is not a V twin as polaris doesn't make any V twins yet. how many miles on it? does it run smoothly or erraticly when idling? wondering if maybe the primary clutch has issues which is throwing the engine out of balance causing vibrations.
Old May 14, 2011 | 08:20 AM
You might check the front motor mount for separation,could be causing engine to flex which in turn affects the clutch alignment. May be the cause of the vibration. 700 and 800's did this from time to time.Or it can be a worn spot on the belt,have had this happen several times. OPT
Jmuddin284
Jan 19, 2026 07:16 AM
Gtsordo
Jul 13, 2015 10:38 PM
jettman
Jul 6, 2015 12:16 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
