The Shee is sick...Please Help
Old Mar 12, 2001 | 01:07 PM
AirBanshee01's Avatar
Well the idle was real low so i tried to ajust it but that didnt quit work as planned. I put the air screw and idle adj screw back to where they were origanily and now when it starts it runs for about 30 seconds and then bogs out. The air screw is set at about 1 oclock and the idles is about 2 oclock. Its either starving for air or fuel. So any help would be great.
Old Mar 12, 2001 | 02:18 PM
Zorro's Avatar
Start it. Let it shut down. Look at your plug. If it's wet, then you don't have enough air, if dry, not enough fuel.
I don't really get what you mean by 2 o'clock for the settings. Normally, I count the setting in turns, 1/2 turns, or even 1/4 turns for the idle screw. Haven't touched the pilot yet.
Old Mar 12, 2001 | 02:31 PM
SteveNB1's Avatar
Peace of cake. You have some junk in the idle jet. Take the carbs off and get a real skinny straight slot screw driver. On the intake side/air filter side of the carb there is a little jet. Take it out and clean it. You might as well clean all your jets (main and mid range). Take off your floats and squirt the dickens out of everything. Put it back together and adjust the air needle. Screw it all the way in and about one full turn out. She will kick the first time and purr for an hour. Oh and punt the foam fitler.
Do you turn to the right or left for more or less air. Thanks for the help.
Old Mar 12, 2001 | 04:33 PM
I checked the plug gap and they where off. Fixed the gap and she runs great now. Never new that would make such a difference.
Screamin96
Feb 19, 2001 11:01 PM
waynaferd
Jan 24, 2001 11:33 PM
Vision
Jan 19, 2001 09:06 PM
Zorro
Dec 21, 2000 10:02 PM
rnl
Apr 24, 2000 09:02 PM
