Chain Question
Old May 25, 2011 | 08:03 PM
mikcee2002Baja's Avatar
Default Chain Question
Ok, so I think I pulled an idiot move. I bought a RK 530 X-RING Chain with 110 links (which I read on here was stock length. am I right?) and the rivet type master link, a 15t primary drive front and 40t primary drive rear sprocket. So I put the sprockets on and then put the chain on. And for some stupid reason I happened to overlook the chain slack. It is pretty bad. I tried adjusting the chain slack but it didnt help much. It still has at least 3 1/2 inches of slack. So does anyone know how I can fix this? I dont understand how I order what was supposed stock length and it has that much slack.
Also, if i have to buy a new chain, can I get a 520 instead of 530? just wondering.
Old May 25, 2011 | 11:34 PM
TheStir's Avatar
Started riding ATVs in 1974!
You can get a clip master link from Rocky Mountain for that chain, you have to cut a few links off to fit. I just did the same combo myself.
What year is your DS? I have the late model swing arm and can count the links I cut off if you want.
Old May 26, 2011 | 12:15 PM
NickDS650's Avatar
thats a good chain, just take some links out
Old May 26, 2011 | 12:30 PM
ok thanks guys. its a 2002. so i just cut the rivet type master link off and a few more links til its tight and then put a clip type on?
Old May 26, 2011 | 04:45 PM
TheStir's Avatar
Yes, have the ends meet on the rear sprocket. You do not want to cut to many links LOL. Been there, done that.
My link count will not be that same as I have a new shorter swing arm on my DS.
Old May 26, 2011 | 09:43 PM
ok sweet! thanks so much for your help stir!! i will be doing that ASAP so i can try out my other goodies as well
Old Jun 5, 2011 | 12:55 PM
DuneRider650's Avatar
I ride a little here and there......
You can use the link it should have came with its a rivet type instead of clip...allot better just cut measure and pound the rivet flat
Old Jun 5, 2011 | 11:20 PM
I already put the rivet in though. but its already done and fixed. works great now with my high comp piston, HMF slip on, big gun CDI, new sprockets, and jet kit.
Firefighter400
Oct 8, 2022 06:38 PM
frostphase
Aug 23, 2015 07:36 PM
Anomers
Aug 16, 2015 11:06 AM
DeFox500
Aug 14, 2015 05:59 PM
95wolv
Jul 17, 2015 08:13 PM
