2005 sp 600 rear shock adjuster
Old May 31, 2011 | 05:50 AM
hurly's Avatar
Default 2005 sp 600 rear shock adjuster
Hello, I snapped the rear shock adjuster on my sportsman 600. Should I buy the adjuster or try and buy a whole used rear shock? I've never had one of these shocks apart so I really don't no if the adjuster would have to be pressed on. Any advise would be greatly appreiciated.
Old May 31, 2011 | 06:06 AM
You have to be able to compress shock spring to remove the upper retainer( the shock tool and a vice makes it easy),remove spring and install new adjuster(just slides on). If shock is still good (not leaking or worn) you can buy just the adjuster and a shop can install for you. I installed new adjusters,shocks and springs for customers that just brought the shock assembly in. OPT
Old May 31, 2011 | 06:32 AM
hurly's Avatar
Thanks OPT...your always there with the answers!!
Bratman2
Aug 6, 2022 01:42 AM
07Redrider400
Jul 25, 2015 05:31 PM
tporath
Jul 11, 2015 12:31 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jkfx400P
Jul 6, 2015 10:04 AM
