need information on coustom pistons
Old Jun 6, 2011 | 10:03 AM
rmax's Avatar
Default need information on coustom pistons
i just aquired a parts engine for our brutes, upon tear down i found a set of monster looking piston, that were man by weisco, after calling weisco tech i learned they were made for 4 stroke tech, but thats all i could find out from them the part #stamped on the dome is10264 m08500, i would like to find out the compresion an application they were designed for, the person i got this motor from run only preminum fuel in it ,my understanding is 12 to 1 an over needs to be put on race fuel or at least a good mixture, there are no signs of damage in the top end , were these designed to run on pump gas. any info will be helpfull, the cams were fst stage 2, i have not gone into the bottom end yet, will later on this week
Old Jun 6, 2011 | 10:29 AM
Doctorturbo's Avatar
GOT BOOST!
Why don't you give four stroke tech a call and give them the numbers and see what they say?
Yes 12 to 1 is knocking on the door of race gas or a mix depending on a lot of things.
Old Jun 6, 2011 | 12:28 PM
rmax's Avatar
they only answer the phone between 2pm an 6pm,an the web site is going through some changes so you can not get info there, an when i tried to email it would not go through either, just hopeing some here my have installed this set up in the past ,an could throw some light on the subject, i really do not believe this set up was intened to go in a brute force
Old Jun 6, 2011 | 03:48 PM
rmax's Avatar
just got off the phone with 4 stroke tech the piston turned out to be as they said true 11.5 to 1, an will work fine on pump gas,
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Sassinm1
Sep 30, 2015 04:23 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
