2002 ds 650 No spark
Old Jun 12, 2011 | 01:50 PM
lanerholloway's Avatar
Default 2002 ds 650 No spark
The other Day i Was riding my bike I shut it off. Went back to start it and it started but die right away. try it agian it started but died agian. Now i have no spark at the plugs. Ive checked all of the fuse there good. Need help dont know where to start on fixing it.
Old Jun 16, 2011 | 08:23 PM
Hightower's Avatar
start with putting a new plug in, it'll run on one so no need to change both to see if this is it...they may be fouled from improper jetting, this can do it.
next check connections of wiring from cdi box to coils - its one wire from cdi that tees to both coils, make sure wire is intact and not shorted to ground and good connection to coils.
next swap cdi box with somebody you know with a DS and see if that's it.
is there a tether kill switch added to the bike? if so disconnect the wire from it going to ground to rule out bad kill switch.
also could check integrity of kill switch on handlebar if none of the above proves out.
Old Jun 20, 2011 | 08:40 PM
Thank for the reply haven't had the time to check all of your suggestion but could it be the Rectifier? just wondering
BigT137
3) General Discussions..
Aug 19, 2015 12:09 AM
Dirtbikemike1
Jul 21, 2015 04:13 AM
coolguy420
Jul 10, 2015 01:17 AM
cSchwartz
Jul 9, 2015 02:43 PM
MNatv89
Jul 7, 2015 11:36 AM
