2002 ds 650 No spark
The other Day i Was riding my bike I shut it off. Went back to start it and it started but die right away. try it agian it started but died agian. Now i have no spark at the plugs. Ive checked all of the fuse there good. Need help dont know where to start on fixing it.
start with putting a new plug in, it'll run on one so no need to change both to see if this is it...they may be fouled from improper jetting, this can do it.
next check connections of wiring from cdi box to coils - its one wire from cdi that tees to both coils, make sure wire is intact and not shorted to ground and good connection to coils.
next swap cdi box with somebody you know with a DS and see if that's it.
is there a tether kill switch added to the bike? if so disconnect the wire from it going to ground to rule out bad kill switch.
also could check integrity of kill switch on handlebar if none of the above proves out.
