sportsman 800 wont start
Old Jun 16, 2011 | 10:46 PM
crabtree's Avatar
Unhappy sportsman 800 wont start
my 09 800 ran fine washed it drove into shop next day it fired up idled fine gave it gas it backfired white smoke rolled out from under gastank and now it wont run changed coil and plugs nothing changed ecu nothing checked spark seems to come and go checked fuel plugs where wet then cranked motor over checked again they were dry fuel seems to come and go like the spark all connections look good and dry
Old Jun 16, 2011 | 11:21 PM
I'd pull the plug caps and clean and use a good electrical grease on them and pull all electrical connections and blow out and use the grease on them also as a start and see if it helps. Others that have had the same problem can probably add more on what to do! OPT
whitty
67
Feb 24, 2021 02:52 PM
neilbedwell
Nov 10, 2018 11:02 AM
gfl0224
Jun 27, 2015 06:52 PM
Raccar1
Jun 18, 2015 02:17 AM
1000gade
May 27, 2015 12:37 PM
