Carb Help!
Old Jun 20, 2011 | 04:04 PM
Dave's Recon's Avatar
Default Carb Help!
Hey guys,
I'm a newby here to the site. Need some help w/ my "07" Honda Recon (TRX 250). Did a stream crossing over the weekend and was too deep. Water got into my airbox and into the engine, oil was like milk. I did 4 oil changes, cleaned and gap checked the plug and dried out the airbox and filter.
Engine fires up, no problem and idles smooth. No electrical probs or shifter probs either. When I start to give it gas though, the engine bogs down and then stalls out every time. I think it's something w/ the carb. Any ideas.....? Thanks so much!
Old Jun 20, 2011 | 04:15 PM
Jaster94's Avatar
remove the carb and clean the jets and the float assembly.......
Old Jun 21, 2011 | 07:08 PM
So I talked to the dealership. They said to flush the carb out and I should be good to go. Never flushed the carb before. Anyone have any info on the best way to do this???? Thanks
Old Jun 21, 2011 | 07:25 PM
420Pimp's Avatar
Basically man there isn't an in depth process to do this. Like the man said above take the bowl off and you can flush it.
1- take carb off
2-take off bowl
3-spray the hell out off it with some carb cleaner, every nook and cranny mainly jets
4-when you put it back together/ on the quad, make sure you dont get any dirt/grime into the carb
P.S. When you take the bowl off of the carb ,pull straight out and dont play with the float. (you wouldn't want to regap the float as this proccess can be a pain in the ballz) When you look in there and see water beads every were, you allready will have the satisfaction of knowing thats the problem
Take your time and dont get rammy
good luck to ya chief
Old Jun 22, 2011 | 02:49 PM
Hey fellas. Took the carb bowl off. Sure enough, there was water and some sludge sitting in there. Cleaned it and flushed it w/ gas and the jets too. All back together and running strong again. Actually runs a little smoother in my opinion and revs up nice. Thanks again for your help!
Old Jun 22, 2011 | 06:33 PM
Jaster94's Avatar
good to hear...........
Old Jun 27, 2011 | 03:55 PM
420Pimp's Avatar
We will all pm you our addresses. Just make the check out for $10,000.
Any time!
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
