99' Xplorer 400 low compression
Old Jun 28, 2011 | 10:01 PM
DitchDigger's Avatar
Default 99' Xplorer 400 low compression
My Xplorer 400 starting having mid-range power issues. Everything is original and has 3-4,000 miles on it. It starts and idles great however I checked the compression and it is 85 psi. Without any know damage to the cylinder should I still get it bored or honed? Or can I just put a new piston in with oversized rings? Should I spring for the Wisco or get the cheaper Numara? Anything I should be considering replacing at the same time?
Thanks
DD
Old Jun 28, 2011 | 10:31 PM
randyneff6971's Avatar
with 85 psi and 3to 4000mi`s the jug is out of round and needs to be re-rounded if your in no hurry take the jug to a machine shop and ask if a .5mm overbore will fix it. if they tell you yes get a new piston and rings .5mm over size, Wisco is the way to go when a redoing your motor. Once you have the new piston take it all the the same shop and have them match it up. the shop will charge (Here in Canada) around $100 and the new piston, rings, and rispin (<-however spelled) will also run you about $100. don`t forget about the gasket set you will need say another $40. I know it sounds like alot but for what the ATV is worth spending $250 and not having to worry about the top end for another 3500 miles is well worth the money spent.
just my .02cents
Old Jun 29, 2011 | 01:20 AM
Wenty's Avatar
Pull the jug and send it out to Rick Ritter. polaris
For around $150-$200 you'll get a bore/hone/chamfer, new Wiseco piston and Gaskets. Done right!
Wenty
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Jason Richards
Sep 4, 2015 06:17 PM
