97 timberwolf 2x4
My rear wheel was loose and bent my lug. I want to replace it myself. It looks like the lugs are welded into the drum/hub, but I have spindles on ebay that look like what i need. Can anyone tell me what I need to purchase and how to install the necessary part for new lugs on the left rear of my 97 2wd timberwolf. Thank you.
If its pressed in you might be able to use a stout vise to press the old one out and the new one in. A hydraulic press works even better. If you don't have access to one a machine shop can do the work.
Good luck
Good luck
