Trail Boss 330 Problem?!?
Old Jul 4, 2011 | 03:35 PM
bc1824's Avatar
Default Trail Boss 330 Problem?!?
hi, we just got a 2001 trailboss 330 fourstroke the other day and today it started to sputter and skip out like it was not getting any gas, but only at a higher rpm. at idle and quarter throttle its fine, once u punch it it bogs down and skips. we checked the airfilter, cleaned the fuel lines and tank, pulled the carb out to clean everything, and still doing the same thing. any suggestions?
Old Jul 4, 2011 | 08:33 PM
scootergptx's Avatar
Supersock
Hired Gun!
Not to nitpick, but I don't think the 330 came out till 2003. Not a huge amount difference, but the jetting for the 330 and the 325 are different.
Did you happen to see what main jet was in the carb while you had it apart?
Old Jul 5, 2011 | 03:24 PM
bc1824's Avatar
oops, yes it is a 325 i just wasnt paying attention, but noo we did not get a good look at the jets, we will pull it back apart and clean then out and such tho, then hopefully it will run strait
Old Jul 5, 2011 | 03:31 PM
Supersock
Hired Gun!
I'd really be leaning towards the jets if it's cutting out.
Just wish they'd have made it a little easier to get to the carb and remove and replace it.
Old Jul 5, 2011 | 03:33 PM
Supersock
Hired Gun!
Was it bought locally? Just a random thought, but if you live in high elevation and it's not jetted right it would be a problem. Or vise versa on that.
Old Jul 5, 2011 | 03:37 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum bc1824!
When you clean the carb.. remove all the jets and the tube like deal the main jet screws into.. their are very small holes going thri the side of that tube.. if they are plugged they would cause the problem your having..
I would also pull the fuel screw out and spray carb cleaner thru all the passages... if youve got compressed air Id use it next... and dont let the carb cleaner get on anything made of rubber... It will grow to a useless size...dont ask me how know that..
Old Aug 3, 2011 | 08:57 PM
carter258's Avatar
im having the same problem with my 2000 trailboss 325. i took the carb apart cleaned it and everything. the guy i bought it from said the engine was fresh and needed to be broke in and after the break in it needed to be rejetted.....true or false? but i live in palm coast and im not too familiar with jetting so could someone please give me some suggestions of the jets to buy? thanks
Old Aug 4, 2011 | 07:50 AM
Supersock
Hired Gun!
I had a 00 boss. Not sure where he got his info, but that isn't true if it's all stock.
Now when you say "fresh" I'm guessing he rebuilt the motor? That and if the pipe and air filter are performance parts could play a big part in jetting.
Old Aug 4, 2011 | 04:15 PM
carter258's Avatar
as far as i know everything is stock, stock pipe and actually has no filter i tried substituting a very thing foam piece as a filter but it doesnt seem to wanna run at all with the foam on. its very breathable foam so im not understanding that. but as far as jets go could you give me some suggestions as to what jets i should need if its all stock. thankss
Old Aug 4, 2011 | 05:39 PM
They are jetted so lean from the factory from the beginning,plus most of the 325 and 330 fuel air screws(that are capped off) need to be opened up on mixture screw,have found some only turned out about 1/2 turn! Need to be about 2 turns out! Most have been hard to warm up even with choke on! Plus without a good air filter,even worse!! OPT
