No 4wd after i changed front axle on a 1998 sportsman 500
Old Jul 13, 2011 | 11:18 AM
chadsportsman500's Avatar
Post No 4wd after i changed front axle on a 1998 sportsman 500
Last week i changed both front axles and ever since i cannot get the awd to work. The light never lit up before but it did work and now nothing
Old Jul 13, 2011 | 12:50 PM
First off the hubs have to be torqued to only 12 foot pounds,too tight or too loose can cause problems,plus if certain the armature plates,hilliards are reinstalled properly and torque is right, and both strut wire connectors are secure,then a lot of times a worn switch in the shift box will cause loss of awd. Most of the ones I encountered the awd light would come on in low range,BUT not in high!(A lot of people left em in high range!) Try pushing on the lever a little harder forward and see if light comes on. If it does,replace the switch in the shift box. OPT
WilliamBos
Sep 30, 2015 08:08 AM
rcappie4
Jun 21, 2015 07:33 PM
mitchetr
Technical and How-To Articles
Jun 10, 2015 08:36 AM
rcappie4
Jun 7, 2015 02:53 PM
blaze_master
May 26, 2015 11:18 AM
