ETON 70 Hot Start Problem
Old Aug 5, 2011 | 07:24 PM
conehead396's Avatar
Default ETON 70 Hot Start Problem
My sons ETON 70 2 stoke will not turn over freely after riding for a while with the electric start. It is not the battery. I used a charger to jump directly to the starter and it was still slow.
When I try it with the kick stater the motor is very tight, almost like it is trying to seize. the compression is good at 110 PSI.
Any ideas? It runs fine If I get it running, and it will start easily after cooling completely down.
Old Aug 6, 2011 | 08:06 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
This isn't good.
Could the fan be broke?
Oil not injecting? When cold, run it and pull the oil line off the carb and make sure it weeps oil.
Old Aug 8, 2011 | 05:07 PM
Well, it ended up being the clutch. Started hearing a rattle in that area Saturday and tore it down.
Not the part with the rollers but the part behind that that is turned by the starter motor.
A screw had backed out it it and it was pretty much done. Ordered a new one and should be good to go.
The part that failed is #5 on this link...
Anything ATV - Kick Starter and Starter Clutch
jag6510
Jun 15, 2015 05:59 PM
brinkkl2000
Jun 11, 2015 12:46 PM
Fnqrider
May 31, 2015 08:29 AM
1000gade
May 27, 2015 12:37 PM
hot_shoe_cv
Oct 13, 1999 02:16 PM
