03 warrior 350 just dies.
My lil brother took his 03 warrior in water half way up the gas tank. drug it to my house, I cleaned it up pulled the carb tore it down and cleaned it up. Drained the oil and changed the filter. Put it all back together and at first it cranked but had no spark, I checked all fuses and all electrical connections. It fired right up and purred like a new one, rode it a bit easy let it warm up then i cracked down on it and it ran strong till i let off the gas and it just died. I lost spark again i know this because i put a spark tester on it. I could get it to run if i unplug the red and blue two wire connector under the shifter side rear fender and plug it back in it will start run for a lil bit and loose spark. Can any one tell me why it is doing this or how i can fix it.
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
