washed my atv
Old Aug 17, 2011 | 05:06 PM
tbott77's Avatar
Default washed my atv
I drove my 2011 polaris 500 out of the garage to spray it down with the hose after a great day of rippin...backed back into the garage and about an hour later went to start it and nothing???? When i turn it over the display lights up for 10 seconds then nothing....i am at a loss....please help.
Old Aug 17, 2011 | 06:55 PM
95wolv's Avatar
Didn't anyone tell you? you can't get a Polaris wet,or dirty, or they won't run....lol. Sounds like you got water into a fuse holder,or have a loose or cracked fitting on a regulator or cdi that allowed water to get in, maybe you will have to unplug all the wires under the seat and by the electronics and blow them out with an air gun to see if there is moisture anywhere, also a good time to dab a little dielectric grease on all plugs to keep out water in the future.
Old Aug 17, 2011 | 07:03 PM
Start by pulling front cover under headlight pod and headlight pod upper part. If you access to an air compressor,blow any remaining water out of areas. Best to remove electrical connections and use die electric grease on connections to seal out any future water problems.Common problem a lot of my customers had and was even worse if they used a high pressure car wash or home unit. Lot of areas water can get into! OPT
Old Aug 18, 2011 | 07:22 AM
tbott77's Avatar
Default Thanks
Guys,
thanks for the responses i did what you guys suggested and an hour later i was up and running again....no more water or mud for this Polaris..LOL
Thanks again
Old Aug 18, 2011 | 07:35 AM
Spdecat's Avatar
It's always a good idea after you wash your machine to start it and let it run for awhile . Let it fully warm up which helps dry things out and prevent problems like you had . I first use a pressure washer then after that I wash by hand usually 2 times a week . In all that time and miles I'l never not had it start , but I don't have fuses to worry about tho .
panicmanic
Sep 20, 2015 05:54 PM
bigred20653
Sep 19, 2015 02:11 PM
Ean
Aug 20, 2015 07:13 AM
WilliamBos
Jul 25, 2015 02:41 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
